Product
Brand
Belkin Rugged Protective Sleeve Case for MS Surface 10" - Blue
Quicklinx: BB6NWS00 Mfr#: F7P353btC01
The ultra-light and protective Type N Go Sleeve is the ideal accessory for your Microsoft Surface. Specifically designed for lap use, it's perfect for typing on uneven areas. Enough room to carry both your keyboard and tablet, it's also slim enough to easily stash in a backpack or handbag.
Using a tablet without a flat surface can often be challenging or just plain uncomfortable. That's why the Type N Go sleeve has ergonomically molded contours. This unique wave-like design props up and secures your device even on subways and bumpy car rides letting you type or watch online content in comfort.
Now it's easy to take your Surface Pro and keyboard all in one slim and convenient case.
Belkin Type N Go - protective sleeve for tablet
Protective sleeve for tablet
Screen Size Compatibility
10"
Material
Durable neoprene
Blue print
Microsoft Surface Pro, Pro 2
Material
Durable neoprene
Blue print
Carrying Case
Protective sleeve
Recommended Use
For tablet
10"
Protection
Scratch-resistant
Closure Type
Zipper
Additional Compartments
Stylus
Stylus holder, soft inner lining, molded
