Belkin Rotating 2.4 Amp Dual USB Mains Charger with AC Passthrough
Quicklinx: BB4SWS00 Mfr#: F8M102af
Charge your smartphone and tablet at home or on the go with the BOOST?UP 2-port swivel charger + outlet. This compact charger includes two universal USB ports, offering convenient one-stop charging for your mobile devices. In addition to the two USB ports, the charger also has an AC outlet, so you can plug in your computer or other appliance while powering your mobile devices. And with 12 watts of combined power, your devices will charge quickly.
This charger swivels 360 degrees, making it easy to fit in tight spaces. This means the charger rotates up and out of the way so it won't block other outlets.
  • Charge two USB devices at once
  • Rotates 360 degrees to fit crowded outlets
Belkin BOOST UP 2-Port Swivel Charger + Outlet power adapter - BS 1363, 2 x USB - 12 Watt
Power adapter
Output Connector Type
Total 3: BS 1363, 2 x USB
Max Electric Current
2.4 A
Power Provided
12 Watt
Power Device Details
2 x - 4 pin USB Type A - 2.4 A , - power BS 1363
Power adapter
Portable player, tablet, mobile phone
Input Connectors
Power BS 1363
Output connectors
Total 3: power BS 1363, 2 x 4 pin USB Type A
Power Provided
12 Watt
2.4 A
2 x 4 pin USB Type A - 2.4 A , Power BS 1363
360° rotation
Equipment Protection Value
1500 British Pounds
