Product
Brand
Belkin Quilted Cover Case with Stand for iPad Air in Rose
Quicklinx: 948NWS00 Mfr#: F7N073b2C02
The Quilted Cover for iPad Air is designed first and foremost to keep your iPad Air safe and secure. Integrated X-Frame design has protective corners made of a soft rubber that gently lock your iPad Air into place. Just bend back the corners when you want to remove it.
The Belkin Quilted Cover iPad Air case is made of a durable material with a sophisticated quilted stitching that adds a bit of refinement and touchable texture. It's then molded to the shape of your iPad Air for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned.
Belkin Quilted Cover - protective cover for tablet
Protective cover for tablet
Ruby
Apple iPad Air
Ruby
Carrying Case
Protective cover
Recommended Use
For tablet
Closure Type
Magnetic closure
X-Frame design
Cover Features
Stand function
Apple iPad Air
