Product
Belkin Qi™ Wireless Charging Pad
Reduced Price - Whilst Stocks Last!
Quicklinx: BB4HWS00 Mfr#: F8M747bt
Stock Status: Clearance
12 left in stock
£12.13 ex VAT
£14.55 inc VAT
Express delivery Order within the next 10 hours for delivery tomorrow
WIRELESSLY CHARGE YOUR MOBILE DEVICES
With the QI Wireless Charging Pad, you can charge Samsung, Nokia and other Qi-enabled smartphones without bothering with plugs or cables. This charger uses Qi-certified transmitting coils to deliver charge to your phone wirelessly. Simply place the phone on the charging pad and wait for the LED indicator to light up. Your phone will begin charging by induction. You'll be able to fully charge your phone without ever having to look for a cable.
RAPID, CONTINUOUS CHARGING
Although the charger works wirelessly, it doesn't sacrifice speed. The charger can bring your phone's battery from zero to 100 percent just as quickly as a conventional, 5-watt wired adapter. With its 1-amp output, the charger delivers power to your phone smoothly and quickly.
ELEGANT, COMPACT DESIGN
You can easily slip the QI Wireless Charging Pad into a pocket or bag thanks to its compact, travel-friendly design. The charger features a small footprint and takes up a minimal amount of space on your desk. And with its elegant design and black finish, it can blend in with any home or office environment.
SOFT PAD KEEPS YOUR PHONE SECURE
The charging pad of the QI Wireless Charging Pad is soft and smooth, providing your phone with a safe cushion while it is charging. The pad's high-friction material grips the phone and prevents it from slipping.
COMPATIBLE WITH ANY QI-ENABLED DEVICE
The QI Wireless Charging Pad can provide a charge to any device with integrated Qi functionality, including the Google Nexus 6, LG G2, and the Google Nexus 7 tablet. Other phones, such as the Samsung Galaxy S5 and Apple iPhone 5/5s, can become Qi-enabled if you equip them with a Qi-receiving battery shell or case.
  • The future is wireless
    With so much added convenience, it's no wonder that wireless charging is gaining popularity. Inductive charging, also known as wireless charging, uses electromagnetic fields to power up compatible devices on contact. Just lay your phone or other Qi compatible devices onto the charging pad and go.
  • Cable-free convenience
    No more cable clutter at your charging station. Simply place your Qi-enabled device onto the pad. Keep charging simple, even when your hands - and days - are full.
  • Elegant, compact design
    With its compact, travel-friendly design, the Qi Wireless Charging Pad easily fits into a pocket or bag. Its small footprint takes up a minimal space on your desk and the elegant design blends in at home or in the office.
Belkin Qi Wireless Charging Pad wireless charging mat
Wireless charging mat
Output Connector Type
On cable: Micro-USB
Cables
Micro-USB cable
Apple iPhone 8, 8 Plus, X; Google Nexus 7; Samsung Galaxy Note8, S III, S4, S5, S6, S6 edge, S7, S8, S8+
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
1 A
Scratchproof, anti-slip base
Micro-USB cable
Apple iPhone 8, 8 Plus, X , Google Nexus 7 , Samsung Galaxy Note8, S III, S4, S5, S6, S6 edge, S7, S8, S8+
Brand: Belkin
Price Range Ex VAT: 0 - 50
