Belkin PRO Series - USB Extension Cable - USB (M) to USB (F) - 1.8m - Moulded
Customer rating: 5.0* (Write a review)
Quicklinx: QVHWS00 Mfr#: F3U134B06
Our Belkin USB Extension Cable extends your existing USB device cable by six feet. With this handy Cable, you’ll never have to struggle with cables that are too short while connecting your printer, scanner, drive, or adapter. Molded-strain relief construction and PVC overmolding ensure a lifetime of error-free transmissions and our Flextec cable jacket is flexible for use in tight areas.
Belkin PRO Series - USB extension cable - USB to USB - 1.8 m
USB extension cable
Shielded
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB extension cable
Shielded
Plated Connector
Gold
Molded
Length
1.8 m
Connector
Customer reviews
Write a review for the Belkin PRO Series - USB Extension Cable - USB (M) to USB (F) - 1.8m - Moulded here!
Cheap but good
Reviewed by . Review Posted 05/11/2005
Before ordering this USB extension cable I popped into PC World to see what they had to offer, I was surprised to find a similar item but they wanted £18 for it.......what a rip-off. Well done dabs, under £2 for this cable is exellent.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
ext cable
Reviewed by blip. Review Posted 29/12/2005
its an extension cable does what the discription says
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
