Arrive at your destination fully charged and ready for portable electronic action. Charge your iPhone, or iPod while commuting or navigating the roads and highways with this 1Amp USB mini car charger.
Charge any USB-enabled device in your car
With the MIXIT Car Charger, you can keep your devices fully charged while you're driving. Ideal for mobile users with an active, on-the-go lifestyle, this charger plugs directly into your car's DC power connector. You and your passengers will be able to charge smartphones, tablets, or other mobile devices, even when you're on the road. -
Faster charging
The MIXIT Car Charger always delivers the maximum amount of power required to charge your device - up to 2.4 amps. This means you'll be able to charge your device faster, saving you hours of charge time. -
Sleek design
Thanks to its low-profile design, the charger plugs in to your car's dash without obstructing your buttons and dials. It is compact and lightweight enough to slip into a pocket or handbag. And with its stylish, metallic finish, it attractively complements your car's interior. -
Reliable charging
Belkin chargers are rigorously engineered to protect your device while it is charging. The charger's intelligent circuitry measures voltage and automatically adjusts power output, ensuring that your device stays safe in the event of an unexpected power surge.
- Belkin MIXIT Car Charger car power adapter - USB
- Product Type
- Car power adapter
- Black
- Output Connector Type
- USB
- Max Electric Current
- 2.4 A
- Product Type
- Car power adapter
- Designed For
- Tablet, mobile phone
- Enclosure Colour
- Black
- Input Connectors
- Automobile cigarette lighter
- Input Connectors Qty
- 1
- Output connectors
- 4 pin USB Type A
- 2.4 A
- LED indicator, charge state recognition
