Belkin Premium MixIt Fast 2.4Amp Mains Charger (UK Plug) - Silver
Quicklinx: BB25WS00 Mfr#: F8M731drSLV
Type: Charger
£17.51 ex VAT
£21.01 inc VAT
The MIXIT Metallic Home Charger offers fast, convenient charging for smartphones, tablets, and any other device that charges via USB cable. This charger plugs directly into your AC wall socket, so you'll always be within reach of a quick battery boost. You'll be able to charge your devices without having to connect them to a computer or bulky docking port.
  • Keep your mobile devices fully charged
  • Faster charging
    The MIXIT Metallic Home Charger always delivers the maximum amount of power required to charge your device - up to 2.4 amps.
  • Universal compatibility
    Thanks to its versatile Ti chipset, the MIXIT Metallic Home Charger is compatible with nearly any device that charges via USB cable. The chipset automatically recognizes devices when they're plugged in, so you'll be able to begin charging without any setup.
  • Interchangeable plug design
    Invest in one charger, and get prepped to travel the world, or only to the destinations that matter.
  • Reliable charging
    Belkin chargers are rigorously engineered to protect your device while it is charging. The charger's intelligent circuitry measures voltage and automatically adjusts power output, ensuring that your device stays safe in the event of an unexpected power surge.
Belkin MIXIT Home Charger power adapter
Power adapter
Silver
Output Connector Type
USB
Power adapter
Enclosure Colour
Silver
Input Connectors
Power BS 1363
Output connectors
4 pin USB Type A
Max Electric Current
2.4 A
Charge state recognition, Smart circuitry
Equipment Protection Value
1500 British Pounds
Type: Charger
Brand: Belkin
Price Range Ex VAT: 0 - 50
