Belkin Premium MixIt Fast 2.4amp Mains Charger (UK Plug) - Grey
Quicklinx: BB24WS00 Mfr#: F8M731drGRY
£16.84 ex VAT
£20.20 inc VAT
The MIXIT Metallic Home Charger offers fast, convenient charging for smartphones, tablets, and any other device that charges via USB cable. This charger plugs directly into your AC wall socket, so you'll always be within reach of a quick battery boost. You'll be able to charge your devices without having to connect them to a computer or bulky docking port.
  • Keep your mobile devices fully charged
  • Faster charging
    The MIXIT Metallic Home Charger always delivers the maximum amount of power required to charge your device - up to 2.4 amps. This means you'll be able to charge your device up to 40 percent faster, saving you hours of charge time. For example, the charger can take an iPad 4th-generation tablet from zero to 100 percent charge in just 6.2 hours, compared to 10.3 hours with a regular 5-watt charger.
  • Universal compatibility
    Thanks to its versatile Ti chipset, the MIXIT Metallic Home Charger is compatible with nearly any device that charges via USB cable (sold separately). The chipset automatically recognizes devices when they're plugged in, so you'll be able to begin charging without any setup.
  • Interchangeable plug design
    Invest in one charger, and get prepped to travel the world, or only to the destinations that matter.
  • Reliable charging
    Belkin chargers are rigorously engineered to protect your device while it is charging. The charger's intelligent circuitry measures voltage and automatically adjusts power output, ensuring that your device stays safe in the event of an unexpected power surge.
Belkin MIXIT Metallic Home Charger power adapter - USB - 12 Watt
Power adapter
Grey
Output Connector Type
USB
Max Electric Current
2.4 A
Power Provided
12 Watt
Power adapter
Tablet, mobile phone
Enclosure Colour
Grey
Input Connectors
Power BS 1363
Output connectors
4 pin USB Type A
Power Provided
12 Watt
2.4 A
Smart circuitry
Equipment Protection Value
1500 British Pounds
Device Type: Galaxy Note
Device Type: Galaxy Tab
Device Type: Galaxy Tab 2
Device Type: Galaxy Tab 3
Device Type: Galaxy Tab 4
Device Type: Galaxy Tab S
Device Type: iPad
Device Type: iPad Air
Device Type: iPad Air 2
Device Type: iPad Mini
Device Type: iPod
Device Type: Nexus 7
Device Type: Tablet
Brand: Belkin
Price Range Ex VAT: 0 - 50
