Belkin Premium MixIt Charge + Sync USB to Micro-USB Cable - Black
Quicklinx: BB62WS00 Mfr#: F2CU021bt04-BLK
Length: 1.22m
£7.13 ex VAT
£8.55 inc VAT
Charge and sync your Samsung Galaxy devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Use the MiXiT UP Micro-USB to USB ChargeSync cable to charge and sync your Samsung at the fastest possible speed. The small, durable micro USB connector also works with most smartphones and tablets with a micro USB port.
The MiXiT UP ChargeSync cable plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
  • Charge and sync your device
    The MIXIT? Micro-USB to USB cable lets you easily connect your device to a charger or computer. Use it to charge and sync any device that has a micro-USB port, including phones and tablets. The cable is ready for use straight out of the box. Simply plug it in to charge, sync media to your device, or upload data to a laptop.
  • Sleek and stylish accessory
    With its matte metallic finish and braided cable jacket, this cable sports a sleek and modern look.
  • Durable design
    Designed to withstand heavy use, the MIXIT? Micro-USB to USB cable can keep up with your active, on-the-go lifestyle. The cable is outfitted with a durable aluminum shell that helps protect it when it's stored in your backpack or bag.
  • Stay connected everywhere
    The ultra-flexible MIXIT? Micro-USB to USB cable is compact enough for easy travel. It coils up for easy storage in a bag or backpack, so you can take it wherever you go. But it is also long enough to reach across a car seat or under a desk, helping ensure that you always have a comfortable connection.
Belkin MIXIT USB cable - 1.22 m
USB cable
Sync and charge, braided
Length
1.22 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB cable
Length
1.22 m
Connector
Length: 1.22m
Brand: Belkin
Price Range Ex VAT: 0 - 50
