Connect your iPod or iPhone to your car stereo, home stereo, portable speakers, sound card or any device that has a 3.5 mm jack. The right-angle plug connects flush against your device, preventing damage to the cable or accidental removal. The cable's flat design prevents it from getting tangled.
Seamless audio connections
The MIXIT Metallic AUX cable provides a firm connection between your audio devices for crisp audio performance. Its quality construction helps minimize interference and noise, so you'll be able to listen to music and movie audio tracks without any crackling or cutouts. -
Sleek and stylish accessory
With its matte metallic finish and braided cable jacket, this cable sports a sleek and modern look. It is available in metallic black, pearl white, gold, silver, and gray, so you'll be able to choose a cable that matches your personal style. -
Durable design
Designed to withstand heavy use, the MIXIT Metallic AUX cable can keep up with your active, on-the-go lifestyle. The cable is outfitted with a durable aluminum shell that helps protect it when it's stored in your backpack or bag. -
Stay connected everywhere
The MIXIT Metallic AUX cable effortlessly coils up for easy storage in a bag or backpack. It's compact enough for easy travel, so you can take it wherever you go. But it is also long enough to reach across a car seat or under a desk, so you'll always have a comfortable connection.
- Belkin MIXIT Aux Cable - audio cable - 1.22 m
- Cable
- Audio cable
- Length
- 1.22 m
- Gold
- Connector
- Mini-phone stereo 3.5 mm - male
- Connector (Second End)
- Braided jacket
- Cable Type
- Audio cable
- Length
- 1.22 m
- Braided jacket
- Gold
- Connector
