Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Quickly charge and sync your devices
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road. -
Compact & portable
The Lightning to USB cable can reach the perfect distance while still being compact enough to toss in a bag and go. It plugs into any USB 2.0 port. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
- Belkin MIXIT Metallic Lightning to USB Cable - Lightning cable - Lightning / USB 2.0 - 1.2 m
- Cable
- Technology
- Shielded
- Length
- 1.2 m
- White
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Sync and charge
- Cable Type
- Lightning cable
- Interface Supported
- Technology
- Shielded
- Shielding Material
- Braid
- Length
- 1.2 m
- Sync and charge
- White
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- MFI
