The Surf Powerline AV+ Passthrough will easily connect your Internet TV, game console or Blu-Ray Live player to the web through any wall socket in your home. The sllim pass-through design to connect prevents wall sockets from being blocked.
Surf Powerline AV+ allows you to reliably transmit content from your Internet directly to your computer and other network devices through the electrical wires in your home. Transfer speeds of up to 200Mpbs makes the Surf Powerline AV+ ideal for streaming media to your home entertainment devices such as gaming consoles and set-top boxes.
Setup of Powerline is simple with its plug-and-play connectivity. Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
- Belkin F5D4079 - powerline adapter kit - desktop
- Powerline adapter kit
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 200 Mbps
- IEEE 802.3, HomePlug AV
- Localisation
- United Kingdom
- Packaged Quantity
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- 200 Mbps
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Port status, power, status
- 1 x 100Base-TX - RJ-45 , 1 x HomePlug AV
- Power Device
- Internal power supply
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- Additional Requirements
- CD-ROM
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
