Belkin Portable Battery Power Pack 2000 with MicroUSB Cable - Black
Quicklinx: BB6WWS00 Mfr#: F8M980btBLK
Charge your smartphone - even when you can't get to a wall outlet. Portable, slim and lightweight, the Power Pack 2000 is the perfect way to ensure your battery won't run out when you're on the go. With 2000 mAh of power, it has the capacity to full charge a cell phone twice or a smartphone once.
A USB to micro-USB cable is included for both charging your battery and recharging the Power Pack. To charge, simply plug the micro-USB into your device and plug the USB into the power pack. A convenient charge indicator lets you know how much power is available. When it's time to recharge, just flip the cable and plug it into your computer or another power source.
  • Retains charge for days
    With the Power Pack 2000, you'll always have a reliable backup if you run out of charging options. The battery pack is rated for 2,000 mAh and remains charged for days after you last plugged it in. Use it to provide your phone with a quick boost for those times when you need to make a call or text.
  • Broad compatibility
    The Belkin Power Pack 2000 is compatible with any device that charges via a USB cable, including most tablets, smartphones, and additional devices that charge with a USB cable.
Belkin Power Pack 2000 power bank - USB
Power bank
Output Connector Type
USB - on cable: Micro-USB
2000 mAh
Cables
Micro-USB to USB cable - 15.2 cm
Power bank
Tablet, mobile phone
Enclosure Colour
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
2000 mAh
