Belkin Smart Cables connect between the Desktop Computer and the KVM. Once connected, the cable converts the video signal (VGA or DVI) from the PC to a compatible signal for the KVM. The KVM is now able to support mix platform environments. Belkin smart cables are fully compatible with Belkin KVMs.
The Belkin Smart DVI to VGA Cable converts analog (VGA) signals to digital in order to support DVI secure KVMs in conjunction with a digital (DVI-D) monitor.
- Belkin OmniView - video / USB cable - 1.82 m
- Video / USB cable
- Length
- 1.82 m
- Connectors
- 15 pin HD D-Sub (HD-15) - female , 4 pin USB Type B - male
- Connectors (Second End)
- 24+1 pin digital DVI - male , 4 pin USB Type A - male
- Designed For
- P/N: F1DN102U, F1DN104U, F1DN108U
- Video / USB cable
- Length
- 1.82 m
- Connectors
- Designed For
