OmniView PRO Series Daisy-Chain Cables allow you to daisy-chain multiple PRO3, PRO2, SMB CAT5, and SE Plus KVM Switches to expand your server configuration. The advanced wiring design and coaxial VGA cabling preserve signal integrity from the first to the last server.
- Belkin stacking cable - 61 cm
- Stacking cable - IEEE-1284
- Technology
- Double shielded
- Shielding Material
- Aluminium
- Wires per Cable
- 25 wires
- Molded, stranded
- Length
- 61 cm
- Connector
- 25 pin D-Sub (DB-25) - male
- Connector (Second End)
- Limited lifetime warranty
- Designed For
- P/N: F1DA104ZEA, F1DA108ZEA, F1DA116ZEA, F1DC108H, F1DC116H
- Network Cable Type
- Technology
- Double shielded
- Aluminium
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 28
- Wires per Cable
- 25 wires
- Pairs per Cable
- 12 pairs
- Molded, stranded
- Length
- 61 cm
- Connector
- Designed For
