Belkin OmniView Soho Series 2-Port USB Dual Headed KVM
Quicklinx: 6KB9WS00 Mfr#: F1DH102LEA
The Belkin SOHO Dual Monitor Desktop KVM Switch lets you share up to two monitors, keyboard, and mouse with up to two computers, saving space on your desk and reducing equipment clutter. The sleek, new design incorporates a built-in USB 2.0 2-port hub with one of the ports conveniently located on the front. This is perfect for connecting an MP3 player, printer, scanner, or any of your USB devices to the KVM Switch while allowing your connected computers to access them. Sensitive push buttons on the front allow for easy switching, and independent audio-switching means you can play music from one computer while accessing files from another.
Belkin OmniView SOHO Series 2 Port KVM Switch with Audio - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Firmware upgradable, built-in 2-port USB 2.0 hub
DC 12 V
32 cm x 14 cm x 14 cm
0.68 kg
3-year warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
4 x VGA HD-15 , 2 x microphone mini-jack , 2 x headphones mini-jack , 2 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 2 x USB Type A , 1 x microphone mini-jack , 1 x headphones mini-jack
External power adapter
DC 12 V
2 x USB cable kit - 1.8 m
32 cm
14 cm
14 cm
0.68 kg
Limited warranty - 3 years
0 - 80%
