Belkin OmniView PRO3 USB & PS/2 8-Port KVM Switch
Quicklinx: 4PJBWS00 Mfr#: F1DA108ZEA
The OmniView PRO3 USB and PS/2 KVM Switch provides easy and dependable server control with extraordinary performance. The Switch enables network administrators to monitor and control up to four, eight, or 16 USB- and PS/2-platform servers from a single console. The PRO Series KVM Switches are the industry's most popular for small to medium server rooms, branch locations, and test and development labs. Designed to grow along with your server network, the Switch can be daisy-chained together using dedicated daisy-chain ports with other OmniView PRO Series or SMB KVM Switches to support up to 256 servers.
Belkin PRO3 KVM Cables are required to connect your servers and computers.
Belkin OmniView PRO3 USB & PS/2 8-Port KVM Switch - KVM switch - 8 ports - rack-mountable
KVM switch - 8 ports - stackable
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
8 x KVM port(s)
On-Screen Display, firmware upgradable
43.8 cm x 19 cm x 4.5 cm
4.2 kg
SunSoft Solaris 8, Novell NetWare 5.x, Microsoft DOS 5.x or later, Apple MacOS X, Microsoft Windows Server 2003, Red Hat Linux 8.x, Microsoft Windows 95/98/ME/NT/2000/XP, Microsoft Windows 7, Microsoft Windows Vista
3-year warranty
Enclosure Type
Desktop, rack-mountable
Subtype
KVM
Ports
8 x KVM port(s)
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1920 x 1440 @ 75 Hz
Status Indicators
Port status
8 x KVM 50 pin Centronics , 2 x network stack device DB-25 , 1 x RJ-11 management , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
External power adapter
1 x serial cable
Rack Mounting Kit
Included
43.8 cm
19 cm
4.5 cm
4.2 kg
Limited warranty - 3 years
0 - 80%
Resources
The following resources are available for the Belkin OmniView PRO3 USB & PS/2 8-Port KVM Switch
