Belkin NetCam Wi-Fi Camera with Night Vision
Installation required? Contact us today!
Quicklinx: 8R0RWS00 Mfr#: F7D7601UK
The Belkin NetCam Wi-Fi Camera with Night Vision makes it easy to check in on your kids after school or watch your pet at play - right on your mobile device. The camera connects to your Wi-Fi router without the need of a computer.
The camera's wide-angle video captures large spaces, while its clear digital audio keeps you from missing conversations or noises. With night vision for recording in low light, NetCam is ideal for baby monitoring. It also lets you save video directly to your mobile device, so you can share your favorite memories.
  • Wide-angle video
    Shows you more of the room so you know what's really going on.
  • Easy mobile-device setup
    Set up your camera from your iPhone, iPad, or Android device in minutes. No need for a computer.
  • Night vision
    Infrared lets you see clearly when there's little to no light.
  • Email alerts
    Enjoy peace of mind with movement-detection notifications.
  • Mobile-device recording
    Save live video to your smartphone or tablet.
  • Digital audio
    Listen to what's going on in the room.
Belkin NetCam Wi-Fi Camera with Night Vision - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Optical Sensor Type
CMOS - 1/4"
Focal Length
3.1 mm
Lens Iris
F/2.6
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Resizing an image, image flip, image mirror
Audio Support
Wired, wireless
United Kingdom
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG
Max Digital Video Resolution
640 x 480
Infrared LEDs
Video Capture
640 x 480 @ 30 fps , 320 x 240 @ 30 fps , 160 x 120 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
3.1 mm
Lens Iris
F/2.6
Horizontal Field of View (degree)
64
Vertical Field of View (degree)
48
Network Interface
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
8R0R C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
8R0R C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.23
8R0R C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.98
8R0R C2G 2m Cat6a Shielded Patch - Blue In Stock £7.38
