Belkin Multi Input Display Adapter
Quicklinx: FCYFWS00 Mfr#: B2B166
This streamlined digital multiport AV adapter makes it easy to connect a laptop or other device to your HDMI projector or monitor. One end of the adapter features four popular output connectors - Mini DisplayPort, USB-C, HDMI and VGA for broad compatibility across many devices. The other end of the adapter features an HDMI connector to input content to your projector or display.
  • Single cable solution
    This multiport digital AV adapter eliminates the need for multiple single-point adapters that cause clutter and are easily misplaced. This neat solution remains connected to the projector/display to eliminate lengthy set-up times or the need for outside help from the IT team. Magnetized cable heads ensure AV installations in meeting rooms, auditoriums, classrooms or exhibition centers stay organized and functional.
  • Security for your network
    Clean, plug-and-play operation functions without additional software downloads, providing added security for all connected devices.
  • Ultra HD 4K Video and Audio icon
    This digital AV adapter supports video resolutions up to Ultra HD 4K and is backwards compatible for lower resolutions for an enhanced video experience. It also supports audio for all audio-enabled inputs - Mini DisplayPort, USB-C and HDMI (VGA does not support audio).
  • USB-A power cable
    The advanced circuitry within the digital AV adapter ensures high-quality performance across all inputs. It is powered by an attached USB-A cable which connects conveniently to your HDMI projector/monitor or a nearby power source for a seamless experience.
Belkin Multiport to HDMI Digital AV Adapter - video / audio cable - Mini DisplayPort / HDMI / USB / VGA - 2.4 m
Cable
Video / audio cable - Mini DisplayPort / HDMI / USB / VGA
Length
2.4 m
Connectors
HD-15 (VGA) - male (input) , Mini DisplayPort - male (input) , HDMI - male (input) , 24 pin USB-C - male (input)
Connectors (Second End)
HDMI - male (output) , USB (power only) - male
4K support
Cable Type
Video / audio cable 4K support
Interface Supported
Length
2.4 m
Recommended Use
Projector, monitor
Magnetised connectors
Connectors
15 pin HD D-Sub (HD-15) - male (input) , Mini DisplayPort - male (input) , 19 pin HDMI Type A - male (input) , 24 pin USB-C - male (input)
19 pin HDMI Type A - male (output) , 4 pin USB Type A (power only) - male
