Belkin MixIt USB to Lightning Cable 3m - Black
Quicklinx: BB35WS00 Mfr#: F8J023bt3MBLKTS
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road. The longer Lightning to USB Cable can reach the perfect distance while still being compact enough to toss in a bag and go. It plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
  • Lightning to USB cable: connect in color
  • Compact and portable
  • Case compatibility
    Depending on the type of case you have, you may need to remove your case before charging. If your speakers, connector port and AUX port are fully exposed when your case is on, you should be able to easily charge and sync your device without removing the case.
Belkin Charge/Sync Cable - Lightning cable - Lightning / USB - 3 m
Cable
Length
3 m
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Length
3 m
Sync and charge
Connector
Apple Lightning - male
4 pin USB Type A - male
