Your basket is empty
Belkin MixIt Colour Range Micro USB Cable 2m - Pink
Quicklinx: BB82WS00 Mfr#: F2CU012bt2M-PNK
Charge and sync your Samsung Galaxy devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Use the MiXiT UP micro USB to USB ChargeSync cable to charge and sync your Samsung at the fastest possible speed. The small, durable micro USB connector also works with most smartphones and tablets with a micro USB port.
The MiXiT UP ChargeSync cable plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
Belkin MIXIT USB cable - 2 m
USB cable
Sync and charge
Length
2 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
Pink
USB cable
Sync and charge
Length
2 m
Pink
Connector
