Product
Belkin MixIt 30-pin Charge + Sync Cable 2m - Purple
Quicklinx: BB8MWS00 Mfr#: F8J041cw2m-PUR
Charge and sync your iPad, iPhone and iPod using just one cable. Simply plug the USB end directly into any USB port. Use the raised bump on 30-pin connector end to correctly orient the cable into your device, every time.
Belkin MIXIT ChargeSync Cable - charging / data cable - 2 m
Cable
Charging / data cable
Length
2 m
Purple
Connector
USB - male
Connector (Second End)
Apple Dock - male
Cable Type
Length
2 m
Purple
Connector
4 pin USB Type A - male
Apple Dock connector - male
