Your basket is empty
Belkin Mix-It single AC Wall charger 2.1amp - Pink
Quicklinx: BB3FWS00 Mfr#: F8J052ukPNK
Use the Home Charger with the Lightning connector for iPad mini to charge faster than ever. And of course, you can still use your 30-pin cable. Charge your iPad or iPad mini at the fastest possible speed with this charger that works in any power outlet.
Belkin Home Charger - power adapter
Power adapter
Output Connector Type
USB
Apple iPad mini; iPad with Retina display (4th generation); iPhone 5; iPod nano (7G); iPod touch (5G)
Power adapter
Enclosure Colour
Pink
Input Connectors
Power BS 1363
Output connectors
4 pin USB Type A
Power Provided
10 Watt
Max Electric Current
2.1 A
Apple iPad mini , Apple iPad with Retina display (4th generation) , Apple iPhone 5 , Apple iPod nano (7G) , Apple iPod touch (5G)
BB3F C2G 2m USB 2.0 A/B Cable - Black In Stock £3.03
BB3F C2G 5m USB 2.0 A/B Cable - Black In Stock £4.28
BB3F C2G 2-Port USB 2.0 Manual Switch In Stock £16.49
BB3F C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.53
BB3F C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
BB3F C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.20
