Connect your laptop to an external monitor using this Mini DisplayPort to VGA adapter. The Belkin Mini DisplayPort to DVI adapter allows you to project content in 1080p high definition resolution from your laptop, or expand your workspace to include a larger monitor.
- Belkin DVI adapter - 12.7 cm
- DVI adapter
- Molded, strain relief
- Length
- 12.7 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-D - female
- Plug and Play
- DVI adapter
- Length
- 12.7 cm
- Connector
- 24+1 pin digital DVI - female
- Plug and Play
