Belkin Micra Fine translucent case for Samsung Galaxy S4 - Blacktop
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 8LFTWS00 Mfr#: F8M566btC00
MICRA SERIES: SERIOUSLY STREAMLINED
Designed using our thinnest material, the Micra Glam Matte Case celebrates the curves and lines of your Samsung Galaxy S4. The Micra Glam Matte Case is easy to take on and off, so you can change your case as often as you change your look.
The Micra Glam Matte Case is designed to protect the buttons on the sides of your Samsung Galaxy S4 while keeping your ports, speakers, and camera fully exposed. Quickly and easily adjust your volume, plug in your headphones, snap a photo, and connect your charging cable while keeping your case on and your phone fully protected.
ULTRA-SOFT TEXTURE
A matte finish gives the case a velvety smooth texture that is soft to the touch. The thin, yet durable, material is a stylish way to keep your phone's surface free of scratches and scuffs, without bulk.
SPARKLING, METALLIC FINISH
Our Micra Glam Matte cases go through a multi-layer finishing process to give them a unique multi-dimensional finish that sparkles like a fine Glam Mattery.
At a Glance:
  • Multi-dimensional metallic finish
  • Hard polycarbonate material
  • Impact and scratch protection
  • Ultra-slim form-fitting design
  • Allows full access to all controls, ports, and camera
Package Includes:
Belkin Micra Glam Matte Case for Samsung Galaxy S4
Compatibility:
Galaxy S4
  • Ultra-soft texture
  • Sparkling, metallic finish
    The Micra Glam Matte cases go through a multi-layer finishing process to give them a unique multi-dimensional finish that sparkles like a fine Glam Mattery.
Belkin Micra Glam Matte - protective case for mobile phone
Protective case for mobile phone
Material
Polycarbonate
Metallic, blacktop, sparkling
Samsung Galaxy S4
Material
Polycarbonate
Carrying Case
Protective case
Recommended Use
For mobile phone
Protection
Scratch-resistant, impact protection
Camera lens cutout, port cut-outs
Samsung Galaxy S4
