Dual functionality
Powerful pass-through charging powers up your iOS device at maximum speed. So, whether you're listening to music or watching videos, using audio navigation, or taking calls while you charge, there's nothing slowing you down. -
3.5 mm audio
The Belkin F8J212 supports any audio jack using the 3.5mm connector with up to 48 kHz, 24-bit audio output for clear conversations and flawless music playback. -
Case compatible
There's no need to remove your iPhone or iPad case to connect your 3.5mm headphones or your charging cable, since the Belkin F8J212 works with most cases.
- Belkin 3.5 mm Audio + Charge RockStar - Lightning to headphone jack / charging adapter - Lightning / audio
- Cable
- White
- Connectors
- Lightning - male
- Connectors (Second End)
- Lightning - female , 4-pole mini jack - female
- Rated Current
- 2.4 A
- Sync and charge
- 2-year warranty
- Cable Type
- Interface Supported
- Lightning / audio
- Rated Current
- 2.4 A
- Recommended Use
- Phone, tablet
- Sync and charge
- White
- Connectors
- Apple Lightning - male
- Apple Lightning - female , Mini-phone 3.5 mm 4-pole - female
- MFI
- Limited warranty - 2 years
