Belkin LEGO® Builder Case for iPhone 5 / 5s - Yellow
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 90CRWS00 Mfr#: F8W283VFC00
CREATE, PLAY, PROTECT
Belkin and the LEGO® Group partnered up to bring to life our shared belief in people, big and small, and the potential of their imaginations. The LEGO® Builder case is the first fully functional, fully customizable case for iPhone 5. A protective case that's fun to play with -- it's the best of both worlds.
TURNS YOUR PHONE INTO A BUILDABLE BRICK
Our LEGO® Builder case is made of a co-molded hard plastic back for scratch-resistance with a semi-flexible outer frame for shock-absorption. The best part is that it's designed with an official LEGO® Base Plate, so you can go crazy customizing it with your favorite LEGO® bricks.
FULL BUTTON PROTECTION
Our Builder case is designed to protect the buttons on the sides of your iPhone 5, while keeping the ports and speakers fully exposed. Adjusting your volume, plugging in your headphones, and connecting your charging cable is fast and easy -- all while keeping your case on and your phone fully protected.
WRAPAROUND FRAME KEEPS SCREEN SAFE
When you put the LEGO® Builder case on your iPhone 5, you'll notice that the edges of the case wrap around your phone ever so slightly. We designed the case this way so when you place your phone facedown on a flat surface, your screen is less likely to get scratched.
At A Glance:
  • Two-tone palette
  • Official LEGO® Base Plate turns your phone into a buildable brick
  • Flexible, easy-to-grip outer frame
  • Impact and scratch protection
  • Slim, form-fitting design
  • Full button protection
  • Turns your phone into a buildable brick
    LEGO iPhone case is made of a co-molded hard plastic back for scratch-resistance with a semi-flexible outer frame for shock-absorption. The best part is that it's designed with an official LEGO base plate, so you can go crazy customizing it with your favorite LEGO bricks.
    The LEGO iPhone case is designed to protect the buttons on the sides of your iPhone 5, while keeping the ports and speakers fully exposed. Adjusting your volume, plugging in your headphones, and connecting your charging cable is fast and easy - all while keeping your case on and your phone fully protected.
  • Wraparound frame keeps screen safe
    When you put the LEGO iPhone case on your iPhone 5, you'll notice that the edges of the case wrap around your phone ever so slightly. Belkin designed the case this way so when you place your phone facedown on a flat surface, your screen is less likely to get scratched.
Belkin LEGO Builder Case - hard case for mobile phone
Hard case for mobile phone
Material
Plastic
Yellow
Material
Plastic
Yellow
Carrying Case
Hard case
Recommended Use
For mobile phone
Protection
Shockproof, scratch-resistant
Port cut-outs, port covers
