The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device. With the iPhone 6 Plus Sport-Fit Plus Armband's Key Pouch feature, carrying cash and keys is convenient and comfortable. The Sport-Fit Plus Armband for iPhone 6 Plus is made of a stretchy neoprene material that's breathable and hand-washable. Sport-Fit Plus iPhone 6 Plus Armband is designed so that the home button and headphone port are fully accessible.
iPhone 6 Plus armband: engineered for the perfect fit
The high-performance Sport-Fit Plus Armband for iPhone 6 Plus doesn't just protect your phone while you're exercising - it's also incredibly comfortable to wear. The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device. -
Key & cash pocket
With the iPhone 6 Plus Sport-Fit Plus Armband's Key Pouch feature, carrying cash and keys is convenient and comfortable. It has been integrated into the back of the armband, so you can stash your car, home or gym locker key, or even emergency cash in the pouch, and you're ready for anything. -
Slim & stylish
The Sport-Fit Plus Armband for iPhone 6 Plus is made of a stretchy neoprene material that's breathable and hand-washable. It fits snug against your arm to give you full access to your screen without adding extra bulk. -
Access to buttons & ports
Sport-Fit Plus iPhone 6 Plus Armband is designed so that the home button and headphone port are fully accessible. You can quickly and easily operate your touchscreen and plug in your headphones while keeping your iPhone 6 Plus inside your armband and on your arm.
- Belkin Sport-Fit Plus Armband - arm pack for mobile phone
- Product Type
- Arm pack for mobile phone
- Material
- Neoprene
- Blacktop
- Material
- Neoprene
- Blacktop
Carrying Case
- Arm pack
- Recommended Use
- For mobile phone
- Washable
- Carrying Strap
- Arm band
- Additional Compartments
- Cash, keys
- Clear screen protector, 2 external side pouches, adjustable hand strap, port cut-outs
