Belkin iPhone 6 Plus case with Cash/Card storage -  Black
Quicklinx: BG9WWS00 Mfr#: F8W610btC00
The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device. With the iPhone 6 Plus Sport-Fit Plus Armband's Key Pouch feature, carrying cash and keys is convenient and comfortable. The Sport-Fit Plus Armband for iPhone 6 Plus is made of a stretchy neoprene material that's breathable and hand-washable. Sport-Fit Plus iPhone 6 Plus Armband is designed so that the home button and headphone port are fully accessible.
  • iPhone 6 Plus armband: engineered for the perfect fit
    The high-performance Sport-Fit Plus Armband for iPhone 6 Plus doesn't just protect your phone while you're exercising - it's also incredibly comfortable to wear. The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device.
  • Key & cash pocket
    With the iPhone 6 Plus Sport-Fit Plus Armband's Key Pouch feature, carrying cash and keys is convenient and comfortable. It has been integrated into the back of the armband, so you can stash your car, home or gym locker key, or even emergency cash in the pouch, and you're ready for anything.
  • Slim & stylish
    The Sport-Fit Plus Armband for iPhone 6 Plus is made of a stretchy neoprene material that's breathable and hand-washable. It fits snug against your arm to give you full access to your screen without adding extra bulk.
  • Access to buttons & ports
    Sport-Fit Plus iPhone 6 Plus Armband is designed so that the home button and headphone port are fully accessible. You can quickly and easily operate your touchscreen and plug in your headphones while keeping your iPhone 6 Plus inside your armband and on your arm.
Belkin Sport-Fit Plus Armband - arm pack for mobile phone
Arm pack for mobile phone
Material
Neoprene
Blacktop
Material
Neoprene
Blacktop
Carrying Case
Arm pack
Recommended Use
For mobile phone
Washable
Carrying Strap
Arm band
Additional Compartments
Cash, keys
Clear screen protector, 2 external side pouches, adjustable hand strap, port cut-outs
