Charge and sync your iPhone 5 with the compact and stylish Belkin Charge + Sync Dock. To use, plug the 4-foot hardwire USB cable into your laptop and dock your device. To charge from the wall, simply plug it into your existing power supply, then plug into any wall outlet.
Charge and sync at the speed of lightning
Charge and sync your iPhone 5 with the compact and stylish Belkin Charge + Sync Dock. To use, plug the 4-foot hardwire USB cable into your laptop and dock your device. To charge from the wall, simply plug it into your existing power supply, then plug into any wall outlet. -
Built-in lightning connector
The Belkin Charge + Sync Dock has a built-in lightning connector, so you can dock your iPhone 5 to charge and sync, hands-free. If your speakers, lightning connector and AUX port are fully exposed when your case is on, you should be able to easily dock your iPhone without removing the case. For best results, remove your case before you dock.
- Belkin MIXIT ChargeSync Dock - docking station for mobile phone, digital player
- Product Type
- Docking station
- Intended For
- Mobile phone, digital player
- Package Content
- Cellular phone / digital player docking station, USB cable (1.2 m)
- Product Material
- Aluminium
- Purple
- Product Type
- Docking station
- Intended For
- Package Content
- Product Material
- Aluminium
- Purple
- Connections
- IPhone / IPod docking - Apple Lightning
- Synchronization function
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
