Belkin iPhone 5 Charge and Sync Desktop Dock - Green
Need a Mobile Tariff ??? See Description Below
Quicklinx: 9S4LWS00 Mfr#: F8J045BTGRN
Charge and sync your iPhone 5 with the compact and stylish Belkin Charge + Sync Dock. To use, plug the 4-foot hardwire USB cable into your laptop and dock your device. To charge from the wall, simply plug it into your existing power supply, then plug into any wall outlet.
  • Charge and sync at the speed of lightning
  • Built-in lightning connector
    The Belkin Charge + Sync Dock has a built-in lightning connector, so you can dock your iPhone 5 to charge and sync, hands-free. If your speakers, lightning connector and AUX port are fully exposed when your case is on, you should be able to easily dock your iPhone without removing the case. For best results, remove your case before you dock.
Belkin MIXIT ChargeSync Dock - docking station
Docking station
Intended for
Mobile phone, digital player
Package Content
Cellular phone / digital player docking station, USB cable (1.2 m)
Product Material
Aluminium
Green
Apple iPhone 5, 5c, 5s; iPod touch (5G)
Docking station
Intended for
Package Content
Product Material
Aluminium
Green
IPhone / IPod docking - Apple Lightning
Synchronization function
Apple iPhone 5, 5c, 5s , Apple iPod touch (5G)
9S4L C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
9S4L C2G 5m USB 2.0 A/B Cable - Black In Stock £5.15
9S4L C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.16
9S4L C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.24
9S4L C2G USB Superbooster Extender Kit In Stock £38.96
9S4L C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
