Belkin iPhone 5 / iPod Touch 5th Gen Charge and Sync Dock (Lightning Connector)
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 8HHPWS00 Mfr#: F8J045BT
Device Type: iPhone 5
Type: Dock
More than 50 in stock
£26.98 ex VAT
£32.37 inc VAT
The Belkin Charge + Sync Dock has a built-in lightning connector, so you can dock your iPhone 5 and iPod touch to charge and sync, hands-free. If your speakers, Lightning connector and AUX port are fully exposed when your case is on, you should be able to easily dock your iPhone without removing the case. For best results, remove your case before you dock.
  • Charge and sync at the speed of lightning
    Charge and sync your iPhone 5 or iPod touch with the compact and stylish Belkin Charge + Sync Dock.
  • Charge sync
    To use, plug the 4-foot hardwire USB cable into your laptop and dock your device. To charge from the wall, simply plug it into your existing power supply, then plug into any wall outlet.
  • Built-in lightning connector
Belkin Charge + Sync Dock - docking station
Docking station
Intended For
Mobile phone
Apple iPhone 5, 5c, 5s, 6; iPod touch (5G)
Docking station
Intended For
Mobile phone
Synchronization function, charging via USB connector
Apple iPhone 5, 5c, 5s, 6 , Apple iPod touch (5G)
Type: Dock
Brand: Belkin
Price Range Ex VAT: 0 - 50
