Belkin iPad Air 2 Slim Style Cover - Stone/Blue
Quicklinx: BB1WWS00 Mfr#: F7N253B1C01
Cleverly constructed to eliminate unnecessary bulk from the case's overall profile, the Belkin Slim Style Cover is the perfect everyday solution. With its same durable materials and thoughtful design details, this case takes sleek protection to a really high level.
  • Ultra thin & incredibly light
    The overall construction and frame design of the Slim Style Cover is incredibly minimalist, giving you maximum protection without adding bulk. The frame is actually embedded into the cover making it virtually disappear once your tablet is in place.
  • Reliable protection
    The Belkin Slim Style Cover is designed foremost to keep your tablet safe and secure. The frame is designed with protective corners made of a flexible silicone that gently lock your device into place. When you close the front cover, a soft inner lining keeps your screen safe from scratches.
  • Comfortable viewing
    Rubberized feet on the frame and a grip suede inner lining prevent your device from slipping and allow you to position your tablet at the angle that suits you best. The experience of using your touchscreen in the viewing position is also improved by integrating a hinge stop into the stand so your screen stays steady while you're typing, swiping or navigating.
  • Perfect typing
    The Slim Style Cover case folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen.
  • Quality craftsmanship & materials
    The Belkin Slim Style Cover is made of durable material with a pinstripe down the front that adds a hint of touchable texture. It's then molded to the shape of your device for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned.
  • Embedded magnets keep everything in place
    The cover features an integrated magnet that keeps the front cover closed when you're on the go.
  • Full access to camera, buttons & ports
    The Belkin Slim Style Cover is designed so that the camera, ports and speakers are fully exposed, so you can quickly and easily snap a photo, adjust your volume, plug in your headphones, and connect your charging cable while keeping your case on and your tablet fully protected.
Belkin Slim Style Cover - flip cover for tablet
Flip cover for tablet
Cyan, stone
Cyan, stone
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Scratch-resistant, spill-resistant
Cover Type
Flip cover
Closure Type
Magnetic closure
Camera lens cutout, microfibre lined, soft inner lining, suede inner lining, velvet inner lining, multiple viewing angle
Cover Features
Stand function
