Product
Belkin Flat 2.4amp Lightning Sync charge cable for Apple items - Purple
Quicklinx: BB07WS00 Mfr#: F8J148bt04-PUR
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Use the 4-foot Lightning to USB cable to charge your iPhone 5, iPad mini, iPad Air, iPad (4th generation) or iPod Touch (5th generation) at fast speeds. Its flat, ultra-flexible design makes it easy to stash without getting tangled.
Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere.
  • Made for iPod/iPhone/Ipad certification
    "Made for iPod," "Made for iPhone," and "Made for iPad" mean that an electronic accessory has been designed to connect specifically to iPod, iPhone, or iPad, respectively, and has been certified by the developer to meet Apple performance standards.
  • Mix & match
    The MIXIT Collection not only includes cables, chargers, audio and power accessories, so you can mix and match with other MIXIT products to create your favorite color combinations.
  • Compact & portable
    The longer 4-foot MIXIT Lightning to USB Cable can reach the perfect distance while still being compact enough to toss in a bag and go. It plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
  • Case compatibility
    Depending on the type of case you have, you may need to remove your case before charging. If your speakers, connector port and AUX port are fully exposed when your case is on, you should be able to easily charge and sync your device without removing the case.
Belkin MIXIT Flat Lightning to USB Cable - Lightning cable - Lightning / USB 2.0 - 1.22 m
Cable
Length
1.22 m
Purple
Connector
Lightning - male
Connector (Second End)
USB - male
Flat
Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable - flat
Interface Supported
Lightning / USB 2.0
Length
1.22 m
Purple
Connector
Apple Lightning - male
4 pin USB Type A - male
MFI
Apple iPad Air , Apple iPad mini , Apple iPad mini 2 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus , Apple iPod nano (7G) , Apple iPod touch (5G)
