Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Use the 4-foot Lightning to USB cable to charge your iPhone 5, iPad mini, iPad Air, iPad (4th generation) or iPod Touch (5th generation) at fast speeds. Its flat, ultra-flexible design makes it easy to stash without getting tangled.
Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere.
MFI-Certified (lets use MFI logo as well)
Compact & portableFast charging & data transferMade for iPod/iPhone/Ipad certificationMix & matchCompact & portableCase compatibilityUltra-compactPlugs into any USB 2.0 port to chargeSyncs music and pictures to/from your laptop in seconds
- Belkin MIXIT Flat Lightning to USB Cable - Lightning cable - Lightning / USB 2.0 - 1.22 m
- Cable
- Length
- 1.22 m
- Pink
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Flat
- Cable Type
- Lightning cable flat
- Interface Supported
- Length
- 1.22 m
- Pink
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- MFI
