Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Flexible charging at the speed of lightning
Use the 4-foot Lightning to USB cable to charge your iPhone 5, iPad mini, iPad Air, iPad or iPod Touch at fast speeds. Its flat, ultra-flexible design makes it easy to stash without getting tangled. Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere. -
Compact and portable
The longer 4-foot MIXIT Lightning to USB cable can reach the perfect distance while still being compact enough to toss in a bag and go. It plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road. -
Case compatibility
Depending on the type of case you have, you may need to remove your case before charging. If your speakers, connector port and AUX port are fully exposed when your case is on, you should be able to easily charge and sync your device without removing the case.
- Belkin MIXIT Flat Lightning to USB Cable - Lightning cable - Lightning / USB 2.0 - 1.22 m
- Cable
- Length
- 1.22 m
- Green
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Flat
- Cable Type
- Lightning cable flat
- Interface Supported
- Length
- 1.22 m
- Green
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- MFI
