Product
Brand
Belkin F9K1121 Wireless Dual Band Router 802.11a/b/g/n (Wall Mounted)
Quicklinx: C0HWWS00 Mfr#: F9K1121uk
  • IEEE 802.11n
The Belkin N600 plug-in router, F9K1121 lets you access the Internet via wired and wireless connection. It is a space-friendly device as it can be wall-mounted for a clutter-free workstation.
Belkin F9K1121 - wireless router - 802.11a/b/g/n - wall-pluggable
Wireless router
Enclosure Type
Wall-pluggable
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Remote Management Protocol
HTTP
NAT support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, Stateful Packet Inspection Firewall (SPIF)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
United Kingdom
2 years warranty
Wireless router
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
HTTP
Encryption Algorithm
128-bit WEP, WPA, WPA2
Status Indicators
Status, WPS
WAN: 1 x RJ-45
Aerial
Aerial
External integrated
Antenna Qty
2
Internal power supply
1 x network cable
United Kingdom
