Belkin F9J1005 Wireless Desktop Router DSL 802.11b/g/n
Quicklinx: C0HTWS00 Mfr#: F9J1005uk
  • IEEE 802.11n
The router is easy setup, get your secure wireless network up and running in minutes. Just three easy steps and you're out of the box and onto the web.
  • Easy setup
    Get your secure wireless network up and running in minutes. Just three easy steps and you're out of the box and onto the web.
  • Preset security
    WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
Belkin F9J1005 - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
WPA2
Communications
DSL modem
ADSL
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL - BT
Aerial
Antenna Qty
2
External power adapter
Enclosure Colour
1 x network cable
United Kingdom
Software Included
Drivers & Utilities, Self-Healing
