The affordable OmniView E Series 4-Port KVM Switch from Belkin allows you to control up to four computers from one keyboard, video monitor, and mouse console. The E Series supports high-resolution display quality when used with coaxial VGA cabling. Designed to work with your PS/2 platform, it reduces desktop clutter and provides a simple, reliable solution at a lower price.
- Belkin OmniView E Series 4 Port KVM Switch - KVM switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Users Qty
- 1 local user
- 21.6 cm x 8.1 cm x 2.5 cm
- 119 g
- System Requirements
- Microsoft DOS 5.x or later, Microsoft Windows Server 2003, Red Hat Linux 8.x, Microsoft Windows 2000 / NT, Microsoft Windows Vista / XP
- Localisation
- Europe
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 1920 x 1440 @ 75 Hz
- 4 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2)
- Localisation
- Europe
- OS Required
- 21.6 cm
- 8.1 cm
- 2.5 cm
- 119 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
