Belkin DuraTek™ Lightning to USB Cable
Quicklinx: D2VRWS00 Mfr#: F8J207bt04-BLK
Length: 1.22m
More than 50 in stock
£23.85 ex VAT
£28.62 inc VAT
Not just any charge cable, DuraTek cables were forged from superior quality materials for ultimate durability. Kevlar fibers reinforce the inner wiring for added strength, abrasion-resistant nylon forms a tough outer jacket, and highly flexible insulation minimizes damage from friction. The strength created by these resilient ingredients is further enhanced by smart design details to reinforce the cable at its stress points. This ensures the finished product can withstand even the most demanding routines, and perform above and beyond expectation to deliver a cable that borders on indestructible.
  • Built with Dupont Kevlar
    One of the key ingredients of DuraTek's secret strength is Kevlar. This resistant aramid fiber is used the world over for everything from bullet resistant vests and crash helmets to surfboards and extreme sports gear. Strong Kevlar strands are built into the cable adding ultimate strength. Able to flex without stretching, these fibers provide structure to keep the wires inside from damage.
  • Double braided nylon
    The external cable braiding is made from a premium and hard-wearing nylon material. Double braiding is a technique used in rope making and gives maximum strength and added resilience. This makes the cable abrasion resistant, more flexible, lightweight and less prone to fraying.
  • Flexible insulation
    Inside the cable, many wires co-exist to provide better functionality and conductivity. Insulation protects the wires from damage as the cable bends and flexes, but some can cause stiffness, affecting the overall suppleness of the cable. The highly flexible insulation within DuraTek minimizes friction, allowing the cable to bend easily and the wires within to move without damage.
  • Better strain relief
    The 18mm strain relief where the cable joins the connector head has been optimized to withstand the greatest amount of bend cycles. Made from flexible TPE, this added length and flexibility helps to absorb stress and reinforce the juncture between the cable and the connector head to prevent separation. Proven in testing to withstand 5000+ cycles where the cable is bent to 180-degrees, this cable is highly resistant to splitting and breakage. Not just flexible, TPE is also smooth, tactile and more environmentally-friendly than the standard PVC.
Belkin MIXIT DuraTek Lightning to USB Cable - Lightning cable - Lightning / USB 2.0 - 1.22 m
Cable
Shielded
Length
1.22 m
Connector
USB - male
Connector (Second End)
Lightning - male
Rated Current
2.4 A
Braided jacket, strain relief
5-year warranty
Apple 12.9-inch iPad Pro (1st generation, 2nd generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, SE; iPod nano (7G); iPod touch (5G, 6G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB 2.0
Shielded
Rated Current
2.4 A
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Aluminium mylar
Length
1.22 m
Connector
4 pin USB Type A - male
Apple Lightning - male
MFI
Limited warranty - 5 years
Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, SE , Apple iPod nano (7G) , Apple iPod touch (5G, 6G)
Length: 1.22m
Brand: Belkin
Price Range Ex VAT: 0 - 50
