Belkin Dual USB Car Charger 2 x 2.4Amp - Black
Quicklinx: D7GMWS00 Mfr#: F8M930BTBLK
17 in stock
£19.47 ex VAT
£23.36 inc VAT
Keep all your devices powered up while on the road with the Belkin BOOST?UP 2-Port Car Charger. This sleek car charger allows you to simultaneously charge up to two devices, making it a great choice for keeping your whole family's devices powered up and ready while on the go.
Thanks to its two USB-A charging ports, the Belkin BOOST?UP 2-Port Car Charger ensures you never have to prioritize which mobile device needs charging the most. Great for giving your phone a little extra juice on the way to work or for keeping children's entertainment devices powered up during long road trips, the BOOST?UP 2-Port Car Charger has a sleek design that fits seamlessly in your car's charging port to keep the entire family connected.
The charger's USB ports are universal, allowing you to pair it with any USB-A cable. As long as you have the corresponding cable, you can use the charger with smartphones, tablets, cameras, portable battery packs, Bluetooth speakers, smartwatches, and more. The built-in LED light lets you know when your devices are charging.
  • Quickly charge two smartphones on the road
  • Charge multiple devices simultaneously
  • Universally compatible to work with any USB-A cable
  • Power up quickly
    This car charger offers combined power of 24 watts (4.8 amps) with each port having a dedicated 2.4 amps. This allows you to charge your smartphones and tablets quickly and safely.
Belkin BOOST UP Car Charger car power adapter
Car power adapter
Output Connector Type
USB
Power Device Details
2 x - 4 pin USB Type A - 2.4 A
Car power adapter
Enclosure Colour
Input Connectors
Automobile cigarette lighter
Output connectors
Total 2: 4 pin USB Type A
Power Provided
24 Watt
Max Electric Current
4.8 A
2 x 4 pin USB Type A - 2.4 A
LED indicator
Equipment Protection Value
2500 US Dollars
Brand: Belkin
Price Range Ex VAT: 0 - 50
