Belkin Cooling Pad v3
Quicklinx: BG9PWS00 Mfr#: F5L091bt
CoolSpot Anywhere keeps your laptop - and your lap - cool and comfortable, whether you're gaming, browsing, sharing or shopping. It minimizes heat to help your legs stay comfortable and your laptop running at its best.
Most laptop cooling pads pull in air from a single bottom vent, which can get blocked when placed on a soft surface like a couch or comforter. The Belkin CoolSpot Anywhere's dual intake vents continuously pull in cool air from both the back and the bottom, giving you the freedom to use your laptop on any surface, hard or soft.
  • Keeps your legs and your laptop cool and happy
  • Works well on any surface - desks, laps, cushions and couches
  • Whisper-like efficiency
    The curved shape of the patented AirFlow wave design creates a continuous, evenly dispersed stream of air flowing under your laptop. This design makes for a quieter fan that won't distract from your music, movies and games.
  • Ergonomic design
    The thin, ergonomic design is lightweight and easy to pick up, even with your laptop. The angled top positions your laptop perfectly for typing, while no-slip ledge holds your laptop in place. Grip pads on the bottom prevent slipping and sliding. The CoolSpot Anywhere seamlessly integrates with any laptop to create a stable surface anywhere you want.
  • Powered by your laptop USB port
    CoolSpot Anywhere is USB-powered, so there's no need to carry around extra cords or a bulky battery pack - just plug it into your laptop and start cooling.
Belkin CoolSpot Anywhere - notebook fan
Notebook fan
USB powered, Airflow Wave
Notebook fan
