Elevate your tablet experience with the Stripe Cover for the iPad Air. They've given one of the best-selling favorites a makeover - with the same durable construction and thoughtful design details now in a fresh look.
Belkin ipad air cases, covers & folios
Elevate your tablet experience with the Stripe Cover for the iPad Air. They've given one of the best-selling favorites a makeover - with the same durable construction and thoughtful design details now in a fresh look. -
Protection
The Belkin Stripe Cover for the iPad Air is designed first and foremost to keep your iPad Air safe and secure. The frame is designed with protective corners made of a flexible silicone that gently lock your iPad Air into place. When you close the front cover, a soft inner lining keeps your screen safe from scratches. -
Viewing
Rubberized feet on the frame and a grip suede inner lining prevent your device from slipping and allow you to position your iPad Air at the angle that suits you best. They've also improved the experience of using your touchscreen in the viewing position by integrating a hinge stop into the stand so your screen stays steady while you're typing, swiping or navigating. -
Typing
The Stripe iPad Air Cover case also folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen. -
Quality craftsmanship & materials
The Belkin Stripe Cover iPad Air case is made of a durable material with a pinstripe down the front that adds a hint of contrasting color and touchable texture. It's then molded to the shape of your iPad Air for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned. -
Embedded magnets keep everything in place
The Stripe iPad Air Cover features an integrated magnet that keeps the front cover closed when you're on the go. -
Full access to camera, buttons & ports
The Belkin Stripe Cover iPad Air case is designed so that the camera, ports and speakers are fully exposed, so you can quickly and easily snap a photo, adjust your volume, plug in your headphones, and connect your charging cable while keeping your case on and your tablet fully protected.
- Belkin Stripe Cover - flip cover for tablet
- Product Type
- Flip cover for tablet
- Plum
- Plum
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Scratch-resistant
- Cover Type
- Flip cover
- Closure Type
- Magnetic closure
- Camera lens cutout, microfibre lined, soft inner lining, suede inner lining, velvet inner lining, multiple viewing angle
- Cover Features
- Stand function
