Belkin Cinema Stripe Case with Stand for iPad Air in Burgundy
Quicklinx: 9480WS00 Mfr#: F7N060b2C01
Elevate your entertainment experience with stripe tab iPad Air cover. The stripe tab cover for iPad Air is designed first and foremost to keep your iPad Air safe and secure. The integrated X-frame design has protective corners made of a soft rubber that gently lock your iPad Air into place. Just bend back the corners when you want to remove it.
The Belkin stripe tab cover iPad Air case is made of a durable material with a pinstripe down the front that adds a hint of contrasting color and touchable texture. It's then molded to the shape of your iPad Air for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned.
Use the stripe tab iPad Air cover to position your iPad Air at the angle that suits you best. The inner lining is set with grooves at various positions so you can slide your iPad Air closer to you or angle it further away - whatever's most comfortable for you.
The stripe tab cover for iPad Air also folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen. The stripe tab iPad Air cover features an integrated magnetic tab that keeps the front cover closed when you're on the go. The same tab can be used to hold the cover back and out of the way while you're using your iPad Air.
  • Stripe tab iPad Air case: a classic favorite, revamped
  • Secure fit
  • Quality craftsmanship and materials
  • Choose your viewing angle
  • Folds into the perfect angle for typing
  • Keep a tab on everything
Belkin Stripe Tab Cover - protective cover for tablet
Protective cover for tablet
Burgundy
Burgundy
Carrying Case
Protective cover
Recommended Use
For tablet
Closure Type
Magnetic closure
Corner protection system, adjustable viewing angles, X-Frame design
