Belkin Charger Worldwide Travel Kit
Quicklinx: BGB4WS00 Mfr#: F8M967btWHT
Type: Charger
£27.63 ex VAT
£33.15 inc VAT
The ability to plug in to local power outlets anywhere in the world is vital for staying connected and safe when work or pleasure takes you out of the country. The Global Travel Kit provides one charger with 6 interchangeable tips that safely cover the 6 dominant power formats across the world. Plus, with 2.4 A output, it gives extremely fast possible charging for all your devices, whatever country you're in.
  • Abroad but not adrift
    The Global Travel Kit contains a universal charger that works with any device, and 6 interchangeable plugs in one box, perfect for multi-destination traveling, wherever your travels take you.
  • Direct to fully charged
    The internal chipset recognizes your device, allowing the maximum required power for fast charging, up to 2.4 A.
Belkin Global Travel Kit power adapter
Power adapter
White
Output Connector Type
USB
Power adapter
Enclosure Colour
White
Input Connectors
Power BS 1363, power NEMA 1-15, power CEE 7/17, power GB 2099-1-1996, Europlug (power CEE 7/16), power AS/NZS 3112
Output connectors
4 pin USB Type A
Power Provided
12 Watt
Max Electric Current
2.4 A
European adapter plug, Australian adapter plug, United States adapter plug, United Kingdom adapter plug, Korean adapter plug, Chinese adapter plug
Type: Charger
Brand: Belkin
Price Range Ex VAT: 0 - 50
