Charge and sync your iPhone 5 or iPod touch with the compact and stylish Belkin Charge and Sync Dock. The Belkin Charge + Sync Dock with Audio Port has been designed to use the cable that came with your iPhone5 or iPod touch, as this product does not come with a lightning cable.
The dock is intentionally designed for easy cable removal, so you can use it in other places like your Mac or in your car. For this reason, your lightning to USB cable may come loose when you remove your iPhone. Docking your iPhone with the AUX jack in the upright position will help increase stability.
To use, first remove the magnetically attached base from the dock. Then, take the Lightning cable that came with your iPhone 5 or iPod touch and feed it through the cable channel. Replace the magnetically attached base and you are ready to dock.
- Belkin Charge + Sync Dock with Audio Port - desktop stand for mobile phone
- Product Type
- Desktop stand
- Intended For
- Mobile phone
- Aluminium
- Product Type
- Desktop stand
- Intended For
- Mobile phone
- Aluminium
- Connections
- Audio input - mini-phone stereo 3.5 mm , Audio output - mini-phone stereo 3.5 mm
