Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
- Belkin High Performance patch cable - 3 m - blue
- Patch cable - CAT 6
- Technology
- Molded, snagless, staggered pin configuration
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Designed For
- Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
- Network Cable Type
- Technology
- Plated Connector
- Gold
- Length
- 3 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- Designed For
- Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
Customer reviews
Write a review for the Belkin Cat6 UTP Snagless Patch Cable Blue 3m here!
Nice bit of kit
Reviewed by Chris Brook. Review Posted 10/01/2006
Nice quality, with neat moulded ends. Does what it says on the tin. Could be cheaper though at nearly £4...
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
