Belkin Cat6 UTP Snagless Patch Cable Blue 1m
Quicklinx: 18KKWS00 Mfr#: A3L980B01M-BLUS
Length: 1m
Colour: Blue
£1.98 ex VAT
£2.37 inc VAT
Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
Belkin High Performance patch cable - 1 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless, staggered pin configuration
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
Network Cable Type
Patch cable - CAT 6
Plated Connector
Gold
Length
1 m
Blue
Connector
RJ-45 - male
RJ-45 - male
Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
Length: 1m
Colour: Blue
Brand: Belkin
Price Range Ex VAT: 0 - 50
