Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
- Belkin High Performance patch cable - 15 m - blue
- Patch cable - CAT 6
- Technology
- Molded, snagless, staggered pin configuration
- Length
- 15 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Designed For
- Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
- Network Cable Type
- Technology
- Plated Connector
- Gold
- Length
- 15 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- Designed For
- Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
