Your basket is empty
Belkin Cat6 Snagless STP Patch Cable (Yellow) 5m
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: 3B3KWS00 Mfr#: A3L980B05MYL-HS
Length: 5m
Colour: Yellow
Stock Status: Clearance
£2.44 ex VAT
£2.92 inc VAT
Express delivery Order within the next 10 hours for delivery on Monday
Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
Belkin patch cable - 5 m - yellow
Patch cable - CAT 6
Shielded twisted pair (STP)
Snagless
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
Network Cable Type
Patch cable - CAT 6
Impedance
100 Ohm
Plated Connector
Gold
Snagless
Length
5 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
Length: 5m
Colour: Yellow
Brand: Belkin
Price Range Ex VAT: 0 - 50
